Tools
Web Help Desk 12.7.6 Hotfix 1 Release Notes
This article describes how to install Web Help Desk 12.7.6 Hotfix 1 on your Web Help Desk server.
9/2/2021 6:37 PM
2/21/2022 7:17 AM
This hotfix resolves the following issues:
  • Issue when upgrading the database from older versions to 12.7.6
  • Issue when ticket modification would not send emails
This hotfix modifies the following file in the <WebHelpDesk>/bin/webapps/WEB-INF/lib directory:
  • whd-core.jar
This hotfix requires Web Help Desk 12.7.6.8342.
See SolarWinds Product Checksums for SHA256, SHA1, and MD5 values.
NOTE: In the installation instructions, <WebHelpDesk> represents the Web Help Desk home folder. The default home folders for various operating systems are listed below:
Operating SystemPath
macOS/Library/WebHelpDesk
Microsoft Windows\Program Files\WebHelpDesk
Linux/usr/local/webhelpdesk
Web Help Desk
Install this hotfix
  1. Stop Web Help Desk.
  2. Navigate to the following directory:
    • <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/
  3. Back up the following files to a separate directory:
    • whd-core.jar
  4. Copy the file included with this hotfix to the /lib directory, overwriting the following file:
    • whd-core.jar
  5. Start Web Help Desk.
    The hotfix is installed.
Uninstall this hotfix
  3. Copy your backup file to the /lib directory, overwriting the following file:
    • whd-core.jar
  4. Start Web Help Desk.
    The hotfix is uninstalled.
For assistance, contact SolarWinds Technical Support.
