Tools
Web Help Desk 12.7.1 Hotfix 1 Release Notes
This article describes how to install WHD 12.7.1 Hotfix 1 on your Web Help Desk server.
12/13/2019 9:44 PM
12/13/2019 9:44 PM
This hotfix resolves the following issues:
  • Word wrapping in the ticket Request Detail field
  • Client UI search based on the request detail does not return a result
NOTE: Upgrading Web Help Desk with this hotfix installed is not supported.
This hotfix modifies the following files in the
<WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/ directory:
  • whd-persistence.jar
  • whd-core.jar
This hot fix also modifies the following file in the
<WebHelpDesk>/bin/webapps/helpdesk/css directory:
  •   whdStyles.css
This hot fix requires Web Help Desk 12.7.1 Build 12.7.1.538.
In the installation instructions, <WebHelpDesk> represents the Web Help Desk home folder. The default home folders for various operating systems are listed below:
OPERATING SYSTEMPATH
Apple® OS X/Library/WebHelpDesk
Microsoft® Windows®\Program Files\WebHelpDesk
Red Hat®/CentOS™
Fedora Linux
/usr/local/webhelpdesk
Web Help Desk
Install this hotfix
  1. Stop Web Help Desk.
    1. Navigate to the <WebHelpDesk> directory.
    2. Right click whd_stop.bat and select Run as Administrator.
  2. Navigate to the following directory:
  3. Back up the following files to a separate directory:
    • whd-core.jar
  4. Copy the following files included with this hotfix to the /lib directory, overwriting the existing files:
    • whd-core.jar
  5. Navigate to the following directory:
  6. Back up the following file to a separate directory:
    • whdStyles.css
  7. Copy the file included with this hotfix to the /css directory, overwriting the existing files:
    • whdStyles.css
  8. Start Web Help Desk.
    1. Navigate to your <WebHelpDesk> directory.
    2. Right click whd_start.bat and select Run as Administrator.
Hotfix 1 is installed.
Uninstall this hotfix
     <WebHelpDesk>/bin/webapps/WEB-INF/lib/
  3. Copy the following backup files to the /lib directory, overwriting the existing file:
    • whd-core.jar
  4. Navigate to the following directory:
  5. Copy the following backup file to the /css directory, overwriting the existing file:
    • whdStyles.css
  6. Start Web Help Desk.
Hotfix 1 is uninstalled.
For more information, contact SolarWinds Technical Support.
