Tools
Web Help Desk 12.6 Hot Fix 2 Release Notes
This article describes how to install Web Help Desk 12.6 Hot Fix 2 on your Web Help Desk server.
- Set up and configure incoming mail in FIPS mode
- Custom fields now save data in all situations
- High asset volume performance issues are resolved
- Linked client accounts no longer restrict views in some situations
- Apache Tomcat version information no longer displays in HTTP 404 pages
- Use as FAQ" now behaves as expected
- Improved functionality with archived request types
- Dashboard widgets no longer time out
server.
Locate the WHD home folder
In the installation instructions, <WebHelpDesk> represents the Web Help Desk home folder. The default home folder for each supported operating system is listed below.| Operating System | Location |
| Apple macOS | /Library/WebHelpDesk |
| Microsoft Windows Server | \Program Files\WebHelpDesk |
| Red Hat CentOS Fedora Linux | /usr/local/webhelpdesk |
Install the hot fix
- Log in to Web Help Desk as an administrator.
- Stop Web Help Desk.
- Navigate to the <WebHelpDesk> directory.
- Right-click whd_stop.bat and select Run as Administrator.
- Download and unzip the Hot Fix 2 ZIP file to a directory on your Web Help Desk server.
- Back up your existing Web Help Desk configuration files.
- In the <WebHelpDesk>/bin/tomcat/conf directory, back up the following file:
- web.xml
- In the <WebHelpDesk>/bin/webapps/helpdesk/error-pages/ directory, back up the following file:
- 404.html
- In the <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/ directory, back up the following files:
- whd-core.jar
- whd-dao.jar
- whd-persistence.jar
- whd-web.jar
- In the <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/ directory, back up the following file:
- web.xml
- In the <WebHelpDesk>/bin/webapps/ROOT/ directory, back up the following file:
- 404.html
- In the <WebHelpDesk>/conf/ directory, back up the following file:
- tomcat_web_template.xml
- Install the files included with this hot fix into the appropriate directories on your Web Help Desk server.
- Copy the following file included with this hot fix to the <WebHelpDesk>/bin/tomcat/conf directory, overwriting the existing file:
- web.xml
- Copy the following file included with this hot fix to the <WebHelpDesk>/bin/webapps/helpdesk/error-pages/ directory, overwriting the existing file:
- 404.html
- Copy the following files included with this hot fix to the <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/ directory, overwriting the existing files:
- whd-core.jar
- whd-dao.jar
- whd-web.jar
- Copy the following file included with this hot fix to the <WebHelpDesk>/bin/webapps/helpdesk/WEBINF/ directory, overwriting the existing file:
- web.xml
- Copy the following file included with this hot fix to the <WebHelpDesk>/bin/webapps/ROOT/ directory, overwriting the existing file:
- 404.html
- Copy the following file included with this hot fix to the <WebHelpDesk>/conf/ directory, overwriting the existing file:
- Start Web Help Desk.
- Right click whd_start.bat and select Run as Administrator.
Uninstall the hot fix
- Locate the directory containing your backup files.
- Install your backup files into the appropriate directories on your Web Help Desk server.
- Copy the following file from backup to the <WebHelpDesk>/bin/tomcat/conf directory, overwriting the existing file:
- web.xml
- Copy the following file from backup to the <WebHelpDesk>/bin/webapps/helpdesk/error-pages/ directory, overwriting the existing file:
- 404.html
- Copy the following files from backup to the <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF/lib/ directory, overwriting the existing files:
- whd-core.jar
- whd-dao.jar
- whd-web.jar
- Copy the following files from backup to the <WebHelpDesk>/bin/webapps/helpdesk/WEB-INF directory, overwriting the existing file:
- web.xml
- Copy the following file from backup to the <WebHelpDesk>/bin/webapps/ROOT/ directory, overwriting the existing file:
- 404.html
- Copy the following file from backup to the <WebHelpDesk>/conf directory, overwriting the existing file:
For assistance, contact SolarWinds Technical Support at http://www.solarwinds.com/company/contact-us.
