Applications Systems
Save WPM recordings as Transaction Checks for SolarWinds Pingdom
Learn how to create recordings in the WPM Web Transaction Recorder and then save them as Transaction Checks that can be used for Transaction Monitoring in SolarWinds Pingdom.
You can use WPM recordings created in the Web Transaction Recorder as Transaction Checks in SolarWinds Pingdom, enabling you to play recordings from a cloud network of probes outside of your firewall, providing a truer representation of external end users.
By combining these two products, you can use WPM's synthetic transactions to monitor the user experience behind your firewall, while Pingdom tracks the real-world user experience across your network and alerts you if sites go down.
Requirements for saving WPM recordings as Transaction Checks in Pingdom include:
- An active Pingdom account.
Not using Pingdom yet? Click here to start your 14-day free trial. - Connect Web Transaction Recorders to your Pingdom account via an API token with Read-Write access, as described in the WPM Getting Started Guide .
To learn more about this integration, see Integrate WPM with SolarWinds Pingdom .
