Tools
WHD asset discovery fails using SCCM
Using Microsoft SCCM to run WHD asset discovery generates a Login failed error message.
10/25/2018 3:03 PM
10/25/2018 3:03 PM
When using Microsoft® System Center Configuration Manager (SCCM) to run Web Help Desk (WHD) asset discovery, SCCM fails with the following error message:
Login failed
Web Help Desk
Use an SQL-authenticated account to connect to the SCCM database. You cannot use a domain-authenticated account because WHD does not support a mixed mode/domain account to log in to the SQL server.
