Security Compliance
What to do if the vulnerability scanner is reporting a cross-domain vulnerability in SEM
The vulnerability scanning utility is reporting a cross-domain vulnerability in SEM.
This issue can occur because of the following:
- The system is not running the latest SEM version.
- The multimanager feature is enabled.
- Upgrade SEM to the latest release and hotfix version.
- If you are not using the multimanager feature, verify that it is disabled.
Note: This feature is disabled by default.- Connect to SEM via the SSH console or hypervisor virtual console.
- Go to the
appliancemenu. - Run
multimanagerconfigand confirm that you want to disable it.
- Restart the Manager service.
- Rerun the vulnerability scan again. If the vulnerability is still reported, contact SolarWinds Support.
