Volume stops reporting after a resize or name change in Orion Platform
The volume usage is not updating in the webconsole after the volume has been resized or renamed.
- This issue occurs when the volume Serial ID has changed and Orion is detecting it as a new volume.
(If a volume is resized or renamed, etc Windows automatically applies a new Serial ID to the device. There is no workaround for this. Solarwinds will recognize the renamed device as a new volume by design).
- Volumes may appear as unknown or appear to be duplicating themselves in the webconsole but this is really caused by when a volume Serial ID changes and Solarwinds recognizes the volume as a 'new' volume.
- Log on to the SolarWinds Web Console using an account that has Node Management rights.
- Go to Settings > Manage Nodes.
- Find the node with the failing volume.
- Click the + icon on the left to expand the node details.
- Select the Volume that has stopped responding and then click Delete.
- Select the checkbox next to the node name.
- Click on List Resources.
- Select all the Volumes to be monitored and click Submit.
- Alternatively, as this can be a tedious process you can set up Network Discovery to auto-discover new Volumes as they become available in your environment - Add Discovered Device to Solarwinds
For a comprehensive list of Volumes that are not currently reporting correctly, you can run the following query against the Orion database
SELECT * FROM Volumes WHERE VolumeIndex <='0' If you wish to display Nodeid, Nodename, Volumename also, run this query: SELECT [dbo].[Volumes].nodeid, node.caption as nodename, [dbo].[Volumes].caption as volumename FROM [dbo].[Volumes] join [dbo].[nodes] node on [dbo].[Volumes].nodeid = node.nodeid where VolumeIndex = 0 group by [dbo].[Volumes].nodeid, node.caption, [dbo].[Volumes].caption
