Volume space alert for specific volume
Creating a space used percentage for Volume - specific Volume.
- Login to Web Console > Settings (upper right hand) > Node & Group Management > Manage Node.
- On the search box type the server involved, click Search.
- Expand the plus button beside the node.
You will see listed the Volume L drive >> right click and open a new tab. - On the new tab > look on the URL > you will see like V: (then a number which is the Volume ID). > Take note of that number for the Drive L.
- Go to Settings > Alerts & Reports > Manage Alerts.
- Click Add New Alert.
- On the 1st tab, Properties > put the name of the alert and description > click Next.
- On the 2nd tab, Trigger Condition Tab > “I want to alert on: VOLUME” > and on the actual Trigger Condition:
All child condition must be satisfied (AND):
Volume: Volume ID is equal to (number of the Drive L)
Volume: Percent Used is equal to (the percentage you want that it will start alert).
- Click Next.
- Reset Condition >> select Create a Special Reset Condition for this alert >> Add condition >> Create new condition.
- Do the reverse of the Trigger Condition. This is will notify you when everything is back to normal base on the value you will put.
- Or you can just put this Reset condition tab on the 1st selection >> Reset this alert when the trigger condition is no longer true.
- Click Next when you are done.
- Leave Time of day at default.
- Trigger Actions > Select the action you want to be alerted. Most common is Send Email/Page.
The information should be straight forward. - Reset Action > is the same action what the Trigger Action will send > so if you have selected Send Email/Page > you have to select the same action.
Note: Make sure the title of the email reset action will be different on the Trigger alert action. - Summary > should display all settings.
- Submit to save.
