Applications Systems
Volume Alerts not triggering for Mount Points
This article briefly discusses one possible reason Alerts may not trigger for Mount Points in Orion & how to resolve this.
- VolumeType parameter returns differently between various vendors. Some vendors class the volume type as 'MountPoint' and the others as 'Mount Point'
- Go to the Manage Alerts screen (Settings > All Settings > Manage Alerts).
- Find the out-of-the-box alert called "Alert me when the free space of a volume is less than 5%"
- Select the alert and click DUPLICATE & EDIT.
- Enable the alert (duplicated alerts are disabled by default).
- Navigate to the Trigger Conditions page.
- Within the actual trigger condition field, click the plus sign and "Add And/Or block."
- Change the 'And/Or' block drop-down to "At least one child condition must be satisfied (OR)"
- Drag the second line of the alert condition into this 'And/Or' block (Volume; Volume Type; is equal to; Mount Point).
- Now edit the single value comparison to the following: Volume, Volume Type, is equal to, "MountPoint."
- Click Next to get to the end of the alert on the Summary tab. Click SUBMIT. The new alert triggers for both specified volume types (Mount Point and MountPoint).
- Back on the Manage Alerts page, disable the out-of-the-box alert called "Alert me when the free space of a volume is less than 5%". Use the new copied alert in place of the SolarWinds out-of-the-box alert for fixed disks.
Apply this amendment to all your Fixed Disk / Mount Point alerts. To find other alerts, sort your alerts by the "Property to Monitor" on the Manage Alerts page. Look for alerts that are based on Volumes.
