Virtual machine hosts missing in the Virtualization Assets resource
ESX hosts are not showing under Virtualization Summary.
11/7/2018 9:10 AM
4/21/2022 7:56 PM
This article can be applied when a Vcenter node details page does not show the individual VMs it is hosting
Orion Platform
This occurs when the ESX host is not in the VIM_Hosts table even if the node is set up as a VMWare server.
  1. Run the following SQL statement to reset the node:
    UPDATE Nodes SET EntityType = 'Orion.Nodes'
    WHERE NodeID='[NodieID]'
  2. Edit the node and select Poll for VMWare.
If the node continues to not show as a virtualization asset, confirm that you can do an ICMP ping from the SolarWinds server to the node in question. The node must respond to PING before it is added as a Virtual Host.
As a suggestion check Firewall rules to allow ICMP Ping through to the device you are trying to add.
