View the DB maintenance and DB defragmentation progress
This article provides information on how you can track the DB maintenance and DB defragmentation progress.
This article provides information on how you can track the DB maintenance and DB de-fragmentation progress.
Part of Quick Orion database health check guide.
You can see the DB Maintenance logs swdebugMaintenance.log from following location:
C:\ProgramData\Solarwinds\Logs\Orion
Scroll to the bottom and it shows the IndexDefragmenation logs and progress.
