View not obeying Single Group Limitation
Limitations for WPM / SRM Not obeying Single Group Limitation. Unrelated objects are displayed when view limitation is applied to a view.
►Create group
►Create view (summary)
►Apply view limitation on single group
►Widgets on the page (specifically events) are showing unrelated objects
