View and monitor additional SNMP data after changing the polling method
This article describes how to view and monitor additional SNMP data after changing the polling method.
10/22/2018 9:47 AM
6/20/2025 8:47 PM
Orion Platform
  1. Reassign the nodes to a new polling engine by clicking Change Polling Engine and then selecting a new polling engine.
Note: The following is an example of change of polling method to collect performance information:
Add a specific polling type (for example: SNMP, Agents or WMI node) and change it to another polling type (for example: ICMP).
  1. After changing the polling engine node, take note of the following:
    • The current number of assigned objects is listed for each available engine.
    • The number is updated with each automatic polling engine synchronization.
    • Updates to the assigned objects count can only be completed for polling engines that are operationally up.
For more information about changing of polling method to collect performance information from monitored devices, such as ICMP, SNMP, WMI, and Agents, please see the following links:
