Tools
View or switch active sessions using RDP session switching in Dameware
This article describes how to enable users to view an active RDP session on a remote machine running a local account.
When you are on a remote session with the end-user, there are times that you don’t see right away the current user desktop, you are just on the Windows login screen. You have the option to either enter the current user credential, which is not ideal, especially if you do not know it, and that is the case most of the time. Or use the feature in Mini Remote Control called RDP session switching to go to the current user session.
- Establish a remote connection.
- Go to the Menu Bar and click Send.
- Select RDP session switching. This displays the list of accounts that are currently connected to the target machine.
- If the Menu Bar is not appearing in DMRC, click the "View Full Screen" button multiple times for the Menu Bar to appear.
***Please keep in mind that the "RDP Session Swtiching..." is only applicable for accounts that have an administrative right. This option will be grayed-out if a non-admin account was used for Remote Connection.***
