Tools
Verify currently running sessions in DRE
Where to check currently running sessions on DRE, where to verify currently online technicians, where to check the number of licenses being taken, and how to check where are the current logins being made.
- Login to your Admin Area.
- Select the Running Sessions menu.
NOTE: This feature is only available for DRE licenses.
