Verify WMI connectivity for Orion Platform products
This article provides information to ensure that the WMI service is installed and running and that you can successfully connect to WMI on a monitored node.
Ensure that WMI is installed
- Log on to the computer.
- Verify that the %Windir%\System32\WBEM directory exists and that it contains WinMgmt.exe
If the folder or EXE file does not exist, install the WMI core manually from http://www.microsoft.com (© 2018 Microsoft, available at https://www.microsoft.com, obtained on November 15, 2018). Follow troubleshooting instructions from Microsoft if you encounter issues with installing WMI.
- Run services.msc.
- Verify that the following services are running and the startup type is set to Automatic.
- DCOM Server Process Launcher
- Remote Procedure Call (RPC)
- RPC Endpoint Mapper
- Windows Management Instrumentation
- Verify that the following service is running and the startup type is set to Manual.
- WMI Performance Adapter
- Ensure that DCOM and networking are enabled
Run WBEMTEST
- Use WMI Control (or Wbemperm.exe: Start > Run... > "wbemtest") to confirm that you have security permissions to access WMI.
- Ensure that the accounts that are used by your management application are able to access WMI and the namespaces that are used by application.
- Review the logs that are available in the %Windir%\System32\wbem\logs directory.
- If a later version of WMI, DCOM, or the operating system (even a service pack) is available, apply that upgrade.
For more information on running the WBEM Test, please check the article here: Testing WMI Connectivity with WBEMTest in Orion Platform .
