Verify Layer 3 polling in UDT
This article describes how to check for Layer 3 polling and whether devices are added to User Device Tracker. The case used is if IP information is missing from the endpoints in UDT.
10/12/2018 8:45 PM
9/8/2023 11:54 AM
This article describes how to check for Layer 3 polling and whether devices are added to UDT.
Case use is if IP information missing from endpoints in UDT.
User Device Tracker
Check to see if Layer 3 devices are added into UDT
  1. Check for if Layer 3 polling is enabled Go to Settings > All Settings > UDT Settings > Manage Ports.
  2. Select Nodes from the Show menu.
  3. If nodes do not appear, add them to UDT. Refer to Add Orion Nodes to UDT.
  1. Go to Settings > Manage Nodes.
  2. Select the required node.
  3. Click Edit Properties.
  4. Scroll down to UDT Node Properties, and verify that Layer 3 polling is selected.
Troubleshoot Layer 3 data
If Layer 3 data (IP Addresses) are not displayed in UDT, verify the following:
  • The device supports all OIDs.
  • The Layer 3 job exists for the node (Settings > All Settings > UDT Settings > View UDT Job Status).
  • The output of UDT Compatibility Checker (Layer 3 target). Try all versions of SNMP protocol – if one of them succeeds, consider changing the device configuration.
  • Verify in the UDT.Jobs log that the job completes successfully,  verify the job duration, and adjust timeout if necessary on the Settings > All Settings > UDT Settings > Advanced Settings page.
  • Verify in the UDT.BusinessLayer log that the job's results are processed successfully
  • Connect to the device and verify the ARP table.
If you are finding that the Layer 3 polling option itself is being unchecked, see Layer 3 polling disabled in UDT for more information.
