VNQM Data Date Time is inaccurate, or Time zone code is not found.
The VNQM data shows the date/time inaccurately or shows that the time zone code is not found, which returns the UTC offset to 0.
4/8/2024 2:18 PM
2/19/2025 9:07 PM
The reports, widgets or web interface will show date/time offsets inaccurately, such as a 1-hour off difference.
VoIP & Network Quality Manager
The Tiimezone codes for offsets are not present in VNQM.
This is a bug in the product.
The errors in the VNQM logs will show a similar message below; this particular message involves Hawaii Standard Time:
WARN  SolarWinds.Orion.IpSla.BusinessLayer.Polling.Cli.TimeZoneManager Dequeue - Timezone code HST not found. Returning UTC offset 0.
Upgrading to 2024.4 will resolve the issue as this is a bug in the product.
For a possible workaround, please generate a support case.
