Applications Systems
VMAN Hyper-V hosts in Unknown status and aren't polled after licensing and polling methods are changed
In rare cases, a Hyper-V host can end up in an "Unknown" state, excluding the host from polling after the host's polling method and licensing tier changes. This article details a workaround solution.
In rare cases, when a host's polling method and licensing tier changes, a Hyper-V host can end up in an "Unknown" state, and the Hyper-V host is excluded from polling.
Symptoms:
- Affected Hyper-V hosts aren't polled and new performance statistics polls aren't populated in the Orion database.
- In the Orion database, affected hosts have HostStatus=0
- Under Settings → Virtualization Settings → Hyper-V Settings, affected hosts show as "Unknown"
- Open the Orion Database Manager.
- Open a new query tab against your Orion database.
- Execute the following query:
UPDATE VIM_Hosts SET HostStatus=2 WHERE HostStatus=0
