Applications Systems
VMAN ESXi hosts polled with host name and IP
Listed hosts in Virtualization summary are polled with IP and hostname.
9/4/2020 2:21 PM
11/11/2021 8:18 AM
  • In the Virtualization Summary view, ESXi hosts are nested with hostname under the correct vCenter, but they are also detected with IP address and do not have assigned vCenter.
  • Vendor and/or Machine Type is Unknown for some virtual entities.
Virtualization Manager
To resolve this issue please follow these steps:
  1. Open Orion Web Console
  2. Navigate to:
    1. In case HTTP: http://{YOUR_ORION_SERVER}/Orion/Admin/AdvancedConfiguration/global.aspx
    2. In case HTTPS: https://{YOUR_ORION_SERVER}/Orion/Admin/AdvancedConfiguration/global.aspx
  3. Locate the following setting: MatchVMWareHostsOnBiosID and make sure it is checked.
  4. Click SAVE button.
Let the environment run for two or three polling intervals and if the issue is still present please contact SolarWinds Technical Support.
