Error VIM_VirtualMachineDisksStatistics_CS_Detail_legacy_U in Orion Configuration Wizard
This article will provide the resolution for the configuration wizard error when upgrading to Orion 2020.2.
6/30/2020 2:38 PM
11/5/2022 12:40 AM
During the upgrade to Orion Platform 2020.2, the Configuration Wizard failed with the following error:
Network Performance Monitor
Resolution 1:
  1. Use an SA account or assign the current account SA server role.
  2. Run the Configuration Wizard and choose the option to create a new SQL account.
  3. Continue with the Configuration Wizard until it completes.
Resolution 2:
  1. Make sure the appropriate permissions are given to the database credential to access the Orion database as per the following articles;
