VCenter credential issue in NPM
VCenter credential issue with these symptoms: Symptoms: - The testing of correct credentials for vCenter failed when you try to add node as VMware node in Orion. - Internet Explorer is not able to pass through certificate warning if you browse https://vCenter/ or https://vCenter/mob - Other browsers (e.g. FireFox) are able to pass through the certificate warning. - The VMware vSphere Client installed on the Orion computer is able to connect to the target vCenter.
Symptoms:
- Other browsers (such as FireFox) are able to pass through the certificate warning.
Environment
Issue occurs on vCenter 4.0.x or its upgraded versions. vCenter 4.1 and above are not affected by Microsoft KB2661254.
VMware provides the following KB article that contains detailed information on how to fix this issue.
http://kb.vmware.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=2037082&sliceId=1&docTypeID=DT_KB_1_1&dialogID=515106271&stateId=1%200%20515112147
