Security Compliance
ARM The Right SQL DB connection setting during initial setup
How to configure DB connection string details to setup ARM DB for first-time users.
4/11/2019 8:13 AM
4/11/2019 8:13 AM
Most first time users of ARM might come across some errors during DB config/setup after installation of ARM. This article will try to minimize these errors and use the correct config where possible.
Access Rights Manager
  • Incorrect SQL connection settings
  • If using Local SQL Server with default instance, the installer should pick up the settings and populate it automatically.
  • If using Remote SQL Server with Default Instance, then you only need to enter the SQL DB hostname and leave Instance name blank.
  • If using Remote SQL Server with Named Instance then you have to enter the DB Hostname, Instance Name values
