Using WBEMTest to verify volume size and free space of nodes in the SolarWinds Platform
This article demonstrates the steps to verify volume size and free space.
11/6/2018 9:56 PM
3/5/2025 12:21 AM
When troubleshooting for volume-related issues in the SolarWinds Platform, you may need to verify the actual data provided by a Windows server via WBEMTest.
Orion Platform
  1. Connect to the SolarWinds Server.
  2. Choose Start -> Run -> WBEMTest.
  3. Click Connect.
  4. In the Namespace, enter.
    \\<IP of DC>\root\cimv2
  5. Enter the username and password you are using in NPM to poll.
  6. Click Connect.
  7. Click on Query.
  8. Enter the following query:
    SELECT Caption, VolumeName, VolumeSerialNumber, Size, FreeSpace, DriveType, MediaType FROM Win32_LogicalDisk
  9. Click Apply.
This should display Win32_LogicalDisk=<no key>. Each of these is a different drive. You will need to double-click each one to find the one which has the C: drive (look in properties box for "Caption CIM_STRING C:").
Now you will see free space and space of the volume. You can check this against your C drive.
