Using Orion with an MS SQL server listening on a custom port
A customer can configure Microsoft SQL to listen on a custom port.
11/15/2018 3:44 PM
2/18/2022 10:16 AM
You can configure Microsoft SQL to listen on a custom port. Refer to this article.
This article reviews the special considerations that must be taken into account in this scenario.
Orion Platform
Note: This is not required if for a named instance. The custom port must allow bidirectional TCP communication if there is any firewall between the Orion server and the SQL server.
By default, Orion speaks to the MS SQL server over port 1433 TCP and 1434 UDP. However, when a custom port is used, you may need to alter the connection string to utilize that port. The example below can be used when specifying what SQL server Orion will use during the Configuration Wizard.
Server(comma)portnumber
Example:  DatabaseServer,17723
