Using the NCM Connection Tester
This article describes how to use the Connection Tester tool as an alternative to PuTTY and other clients. This tool is part of Network Configuration Manager (NCM) and is located in the installation folder of NCM.
11/29/2018 10:57 PM
12/13/2021 7:24 PM
This article provides instructions on how to use the Connection Tester tool as an alternative to PuTTY and other clients. This free Kiwi Syslog Server Tool is bundled with certain versions of NCM and is located in the installation folder of NCM.
Note: The free KiwiSyslogTool was removed in NCM 2020.2.x and later versions. Earlier installations that upgrade can still continue to have the tool as it was "grandfathered".
  1. Log in to the Orion Platform server.
  2. Go to the folder location.
    Note: The default location is C:\Program Files (x86)\SolarWinds\Orion\NCM\Tools
  3. Execute ConnectionTester.exe
  4. Supply the necessary credentials when connecting to the device.
  5. Click Connect.
  6. Verify the information on the Connection Log.
