Using Fprobe to send flows from a Linux box to NTA
Fprobe is a Linux solution similar to nProbe for Windows. Fprobe is a libpcap-based tool that collects network traffic data and emits it as NetFlow flows towards the specified collector. This allows you to span or mirror a port from your network device that is not flow-capable and use Fprobe to create flows for analysis in NTA.
10/20/2018 5:55 PM
7/22/2026 10:38 PM
Details on nProbe for Windows users here:
http://thwack.solarwinds.com/community/solarwinds-community/product-blog/blog/2009/11/10/orion-nta-and-nprobe-analyzing-bandwidth-hogs-without-flow-capable-network-equipment.
Netflow Traffic Analyzer
This article assumes you have Fprobe installed on a Linux box and are attempting to send flows to NTA. Fprobe can be downloaded from most repositories or here: http://fprobe.sourceforge.net/
You need to run two processes, one for in and one for out. These are designed for high load:
/usr/local/fprobe/sbin/fprobe -x1:2 -ieth1 -B4096 -r2 -q10000 -t10000:10000000 -a 1.1.1.1 2.2.2.2:2055
/usr/local/fprobe/sbin/fprobe -x2:1 -ieth1 -B4096 -r2 -q10000 -t10000:10000000 -a 1.1.1.1 2.2.2.2:2055
Explanation:
1.1.1.1 = Source IP
2.2.2.2 = NetFlow collector IP (This should be the NTA IP)
2055 = Collector port
X1:2 = InPackets
X2:1 = OutPackets
