Tools
Use a UDL file to create connection string
This article aims to help troubleshoot and build a connection string for the Log to Database action.
- Create the following file:
- C:\test.udl
- Run the following command to run the UDL in 32-bit Mode:
C:\Windows\syswow64\rundll32.exe "C:\Program Files (x86)\Common Files\System\Ole DB\oledb32.dll",OpenDSLFile C:\test.udl
- Configure the UDL to use the needed Provider and Connection settings.
- Note: For Oracle servers, set the Data Source field to one of the following:
(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST={Server_Name})(PORT={Port}))(CONNECT_DATA=(SERVER=DEDICATED)(SERVICE_NAME={SID}))) {Server_Name}:{Port}/{SID} - Note: Replace {Server_Name}, {Port} and {SID} with actual values.
- Uncheck the option for Blank Password and check the option to Allow Saving Password.
- Click Test Connection.
- Assuming the test is successful, click OK and open C:\test.udl in notepad.
- Copy the connection string in this file to the Log to Database Action.
