Tools
Use Dameware Mini Remote Control to create an MSI file to connect to a gateway and register in remote host list
This article describes how to use the DMRC Client Agent MSI Builder to build a Windows Installer (MSI) package that is used to install the Dameware Mini Remote Control (MRC) Client Agent Service on a remote machine. The Dameware MRC Client Agent MSI Builder is included in version 6.x and later and enables you to build custom MSI packages including any custom settings (INI or Registry) to deploy the DMRC Client Agent Service in the target environment.
- Go to installation folder, and then open .
- Launch Dameware Mini Remote Control Client Agent MSI Builder.
- Select the appropriate target operating system.
- Click Client Agent to make any modifications through the Dameware Mini Remote Control Properties GUI.
- After all modifications have been completed, click OK to exit the Dameware Mini Remote Control Properties window.
- Click ... to specify the output folder.
- Click Build MSI to build the custom MSI package containing all the custom settings which will be created in the output folder.
Notes:
Dameware partners with RSA Security, Inc. to use the BSAFE Crypto-C Micro Edition cryptography module, which meet all Level 1 requirements for Federal Information Processing Standards (FIPS) 140-2 compliance when operated in FIPS Mode. However, in order to take advantage of this new FIPS Mode option, the RSA FIPS Modules must also be on the remote machine. This can easily be included in the MSI package by enabling the Include FIPS Modules option. When this new FIPS Mode option is set, Dameware MRC exclusively uses the BSAFE Crypto-C ME FIPS 140-2 validated cryptographic library. This library allows only FIPS-approved algorithms to be used. The new FIPS mode functionality is included in version 6.7 and later of Dameware Mini Remote Control:
- The oldest versions of Dameware MSI Builder did not support the creation of installation packages for 64-bit operating systems. Manually install Dameware MSI Builder, or install it through the Dameware NT Utilities Service View. It can also be installed directly from within Dameware MRC.
- To build MSI packages with the Dameware MRC Client Agent MSI Builder (DMRCSMSI.EXE), the local machine must be running Windows 2000 or later, and also have Microsoft Windows Installer (MSI) 2.0 or later. MSI 2.0 should be automatically included in Windows 2000-SP1 and later. Only MSI 1.1 or later is required to run MSI packages created by the MSI Builder. Refer to the following Knowledge Base articles from the Microsoft website for more information:
- Windows Installer (© 2017 Microsoft, available at https://msdn.microsoft.com/, obtained on February 06, 2017.)
- Windows Installer Redistributables (© 2017 Microsoft, available at https://msdn.microsoft.com/, obtained on February 06, 2017.)
- Include FIPS Modules (version 6.7 and later only)
Remote Agent
When the MSI package is generated, it contains all specified settings. To enable unattended connections, install the MSI package with special transform files MST.
Part I
The default location is:
- Go to
- Find the appropriate MST file.
- Copy the file to the output folder specified in the Dameware MRC installation package builder.
Part II
- Open CMD.
- Enter the following command:
- Follow the instructions provided in the Windows installer.
If you want to use only MSI Package without any configuration MST file, you can use Orca Editor to generate a package that contains all configurations.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
