Tools
Use Dameware Mini Remote Control to connect remotely to Linux and Mac clients
This article is about remote connections to MAC and Linux. Starting with version 9.0, Dameware Mini Remote Control (MRC) supports connections to remote Linux and Mac clients. In the latest version, select Use VNC Viewer in the Remote Connect dialog to establish the appropriate connection. MRC can connect to the following Linux distributions with VNC enabled: Debian 5 and later CentOS 5 and 6 Ubuntu 10.04.1 - 10.04.3 LTS, 11.10, and 12.04 LTS Red Hat Enterprise Linux 5 and later Fedora 15 and 16
10/8/2018 12:05 AM
2/14/2022 12:15 PM
Starting with version 9.0, MRC supports connections to remote Linux and Mac clients. In the latest version, select Use VNC Viewer in the Remote Connect dialog to establish the appropriate connection.
  • Debian 5 and later
  • CentOS 5 and 6
  • Ubuntu 10.04.1 - 10.04.3 LTS, 11.10, and 12.04 LTS
  • Red Hat Enterprise Linux 5 and later
  • Fedora 15 and 16
Notes:
  • VNC connections require the remote clients to be configured as VNC servers. See the procedures in this article for examples of how to set up a Linux or Mac client.
  • VNC servers use different credentials from those the operating system uses. When you select the Use VNC Viewer option, provide the password for the VNC server, not the OS.
  • MRC stores the credentials for each client on a client-by-client basis only, not by connection type. If you switch between connection types for a single client, ensure the stored credentials are valid for the selected connection type.
Dameware Remote Support & Mini Remote Control
The procedure to set up a VNC server on a remote system vary based on the operating system and version the system is running. The following procedures illustrate typical scenarios for Linux and Mac clients.
To configure a VNC server in Linux using the Gnome Remote Desktop:
  1. Open the Gnome desktop preferences. For example, in Fedora distros:
  2. Click the Fedora icon.
  3. Go to Desktop > Preferences, and then select Remote Desktop Preferences.
  4. Configure the settings according to your preferences.
  5. Click Close.
To configure a VNC server in Mac OS X 10.7
  1. Click the Apple menu, and then select System Preferences.
  2. In the Internet and Wireless section, click the Sharing icon.
  3. Select Screen Sharing, and then click Computer Settings.
  4. Select VNC viewers may control screen with password, and then enter a password for VNC connections.
  5. Click OK.
