Upgrade fails due to Configuration Wizard error linked to '_dta' index
User encounters error during upgrade and shows issue with '_dta' index.
4/17/2026 8:40 PM
4/17/2026 9:23 PM
The following can be seen in the log at C:\ProgramData\SolarWinds\Logs\Orion\ConfigurationWizard.log:
2026-04-17 12:01:52,860 [13] ERROR DBConfigProcessor - Error while executing script - The index '_dta_index_IPAM_Node_7_1412200081__K5_K1_K2_K4_K7_K8_3_9_11_12_14_15_16_18_20_21_23_25_28_30_32' is dependent on column 'IPNodeId'.
The index '_dta_index_IPAM_Node_7_1412200081__K2_K1_K12_K28_K5_3_4_7_8_9_11_14_15_16_18_20_21_23_25_30_32' is dependent on column 'IPNodeId'.
ALTER TABLE ALTER COLUMN IPNodeId failed because one or more objects access this column..
 Error details: System.Data.SqlClient.SqlException (0x80131904): The index '_dta_index_IPAM_Node_7_1412200081__K5_K1_K2_K4_K7_K8_3_9_11_12_14_15_16_18_20_21_23_25_28_30_32' is dependent on column 'IPNodeId'.
2026-04-17 12:01:52,860 [13] ERROR DBConfigProcessor - Failed on C:\Program Files (x86)\SolarWinds\Orion\OrionCoreDatabaseScheme.dbConfig script with error SolarWinds.ConfigurationWizard.Common.ConfigurationException: Error while executing script- The index '_dta_index_IPAM_Node_7_1412200081__K5_K1_K2_K4_K7_K8_3_9_11_12_14_15_16_18_20_21_23_25_28_30_32' is dependent on column 'IPNodeId'.
2026-04-17 12:01:52,876 [13] ERROR TaskAdapter - Error running task Orion.ConfigureDatabase SolarWinds Platform Database
Network Performance Monitor
The indexes and statistics that start with the prefix _dta
Back up the database first before proceeding.
  1. Run the query below directly from SQL Server Management Studio:
DECLARE @sql NVARCHAR(MAX) = N'';
SELECT @sql += 'DROP INDEX ' + QUOTENAME(i.name) + ' ON ' + QUOTENAME(SCHEMA_NAME(t.schema_id)) + '.' + QUOTENAME(t.name) + ';'
FROM sys.indexes i
INNER JOIN sys.tables t ON i.object_id = t.object_id
WHERE i.name LIKE '_dta%';
2. Turn off the Database tuning advisor by running the next script.
-- Disable automatic plan forcing (reverting to last good plan)
ALTER DATABASE [YourDatabaseName]
SET AUTOMATIC_TUNING ( FORCE_LAST_GOOD_PLAN = OFF );
3. Once done, re-run the Configuration Wizard.
