Upgrade IOS (firmware) using NCM
Article provides information on how to upgrade Cisco IOS (firmware) on devices using NCM.
NCM admin guide topic: Upgrade IOS and Firmware (NCM 7.6 and above)
Cisco document: https://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/upgrade.html (© 2018 Cisco, available at https://www.cisco.com/c/en/us/index.html, obtained on 2018).
You can use an Execute a command script to update the IOS:
1. Place the firmware image onto a TFTP server
2. Create a script for downloading and deploying the firmware
3. Schedule a job to execute the script at the time which suits you
These scripts are not provided by SolarWinds and use them on your own risk. As Config Change Scripts are considered to be customization, Technical Support is not creating or supporting them.
Note: While it is possible to store the .bin file in the TFTP root, it is not an NCM function to manage them.
Following Thwack posts will help to get the pre-configured example script:
