Updates & Evaluations is stuck in Checking for potential programs
The My Orion Deployment > Updates & Evaluations is stuck in Checking for potential programs when doing a System Check
11/10/2020 8:55 PM
8/2/2022 8:40 AM
Network Performance Monitor
  • Permission of Network Service in Full Control for the C:\Windows\Temp folder is not set.
  • Administration Service is not running/working properly.
Check the 'Network Service' account permission on C:\Windows\Temp folder
  • Right Click on the C:\Windows\Temp folder.
  • Go to the Security tab
  • Verify if the Network Service has Full Control to the folder.
  • If none, please click Edit
  • Select 'Network Service'
  • Check 'Full Control'
  • Click Apply
  • Re-run the Updates and Evaluation again
If still have issues, please try below
  • Open the Orion Service Manager - Restart Solarwinds Administration Service on all the pollers
  • Login to WebConsole again
  • Run all HealthChecks again and ensure the last run timestamp is updated.
  • If there is still a problem, go to the Control Panel > Programs and Features. Repair the Active Diagnostics and Administration Service.
