Applications Systems
Update PSLanguageMode PowerShell settings for target AppInsight for Exchange nodes in SAM
Starting in SAM 2020.2.6, a minimum of RestrictedLanguage is required for the PSLanguageMode setting on target servers. This article includes a PowerShell script that you can run on Exchange servers to adjust that setting.
7/15/2021 5:13 AM
7/15/2021 5:13 AM
To support AppInsight for Exchange, earlier versions of SAM used PowerShell FullLanguage mode on target servers. Starting in SAM 2020.2.6, a minimum of RestrictedLanguage is required for the PSLanguageMode setting on target servers.
Note: SolarWinds recommends using PowerShell 5.1 or later on target servers.
Use the following PowerShell script to reconfigure the IIS endpoint of existing Exchange machines to change the PSLanguageMode Setting to RestrictedLanguage.
$CantSetupLanguageMode = 16026
	$ExitCodeOk = 0
	### Functions declaration ###
	function ExitWithCode {
	Param($ExitCode)
	$host.SetShouldExit($ExitCode)
	exit
	function Configure-PSLanguageMode {
	Param($webSitePath)
	try {
	Write-Output "Current value of PSLanguageMode setting on PowerShell site: "
	$psLanguageMode = Get-WebConfiguration appSettings/* $webSitePath | select key,value | where {$_.key -eq 'PSLanguageMode'}
	Write-Output $psLanguageMode | Out-String
	if ($psLanguageMode -eq $null) {
	Write-Output "PSLanguageMode key is missing inside web.config\appSettings section. Will create one..."
	Add-WebConfigurationProperty -pspath $webSitePath -filter "appSettings" -name "." -value (@{key='PSLanguageMode'; value='RestrictedLanguage'})
	} elseif ($psLanguageMode.value -eq "FullLanguage") {
	Write-Output "Switch PSLanguageMode setting to RestrictedLanguage for PowerShell site"
	Set-WebConfiguration -filter '/appSettings/*[@key="PSLanguageMode"]' -PSPath $webSitePath -value (@{value="RestrictedLanguage"})
	Write-Output "To apply PSLanguageMode setting we have to recycle application pool: "
	# Get pool name by the site name:
	$pool = (Get-Item $webSitePath | Select-Object applicationPool).applicationPool
	Write-Output $pool
	# Recycle the application pool:
	Restart-WebAppPool $pool
	Start-Sleep -s 15
	Write-Output "Check PSLanguageMode setting: "
	} catch {
	Write-Output "Unable to setup PSLanguageMode setting for PowerShell web site. ERROR: $($Error[0])"
	ExitWithCode $CantSetupLanguageMode
	$webSitePath = "IIS:\sites\Default Web Site\PowerShell"
	Write-Output "Configuring PSLanguageMode setting for web site: "
	Write-Output $webSitePath
	Configure-PSLanguageMode $webSitePath
	$hasExchangeBackEndWebSite = Get-WebSite | where {$_.name -eq 'Exchange Back End'}
	if ($hasExchangeBackEndWebSite -ne $null) {
	Write-Output "Detected second PowerShell web site instance under 'Exchange Back End' web site, probably system is running Exchange 2013. Will configure second instance as well.."
	Write-Output "##############"
	$webSitePath = "IIS:\sites\Exchange Back End\PowerShell"
Server Application Monitor
