Unused Port Report with Admin and Oper status included
This article describes how to create a custom report (that includes operational and administrative status for each reported port) in report writer or SQL query for Unused ports.
- Open Orion Web Console.
- Navigate to Reports > All Reports > Manage Reports.
- Create a new Report.
- On Add Content, add a Custom Table Resource.
- On the Selection Method choose Advanced Database Query and then SQL.
- Copy and paste the query below:
SELECT UDT_UnUsedPorts.NodeID AS NodeID, UDT_UnUsedPorts.PortID AS PortID, UDT_UnUsedPorts.DNS AS DNS, UDT_UnUsedPorts.IP_Address AS IP_Address, UDT_UnUsedPorts.Name AS Name, UDT_UnUsedPorts.PortDescription AS Port_Description, UDT_UnUsedPorts.DaysUnused AS DaysUnused, UDT_Port.PortID AS PortID2, UDT_Port.AdministrativeStatus AS AdminStatus, UDT_Port.OperationalStatus AS OperStatus FROM UDT_UnUsedPorts INNER JOIN UDT_Port ON UDT_Port.PortID = UDT_UnUsedPorts.PortID WHERE ( CAST(UDT_UnUsedPorts.DaysUnused AS INT) >= 0 OR UDT_UnUsedPorts.DaysUnused = 'Never' ) AND UDT_Port.AdministrativeStatus = 1 AND UDT_Port.OperationalStatus = 2
- Press Add to Layout.
- On the Edit Resource page click Add Column.
- Select all the columns and press Add Column.
- Press Submit and finish the wizard.
