Uninstall all SolarWinds Platform products from a server and prepare for reinstall
Uninstall your entire SolarWinds Platform deployment (all SolarWinds Platform products) from a server and prepare for reinstallation.
11/29/2018 10:40 PM
12/1/2025 3:54 PM
This article provides instructions to uninstall all SolarWinds Platform products from a server and prepare for reinstallation.
Orion Platform
  • A failed or incomplete install/upgrade
  • High Availability issues
  • Product version mismatch
Before you start
  • Back up the SolarWinds Platform database, folders, and registry keys.
  • Make sure you are logged in with the built-in local Administrator account.
  • If installed, uninstall the SolarWinds Platform SDK.
Orion and SolarWinds Platform products 2019.2 and later
Starting with Orion Platform 2019.2, you can uninstall the entire Orion Platform deployment using the SolarWinds Platform Installer.
If you have scalability engines deployed, run the following steps on each scalability engine (additional polling engines, HA backup servers, and additional web servers) and then repeat the steps on the SolarWinds Platform server (the main polling engine).
  1. Locate the SolarWinds Platform installer .exe file on the server.
  2. In a command prompt, run the following command:
    '<path>'\<fileName>.exe -uninstall
    For example:
    C:\Users\UserName\Downloads\Solarwinds-Orion-NPM.exe -uninstall
  3. Follow the on-screen instructions to complete the uninstallation.
  4. Reboot the server after uninstallation completes.
  5. Make sure that the following folders were removed:
    • C:\Program Files (x86)\SolarWinds
    • C:\Program Files (x86)\Common Files\SolarWinds
    • C:\inetpub\SolarWinds
    • C:\ProgramData\Solarwinds
    • C:\ProgramData\SolarWindsAgentInstall
All SolarWinds Platform products are removed, including all relevant registry entries and folders. The SolarWinds  Platform database is not removed.
Orion Platform products 2018.4 and earlier
  1. Open SolarWinds License Manager and deactivate your license.
  2. Go to Programs and Features (Run > appwiz.cpl) and sort the list by Publisher.
  3. Uninstall all programs under SolarWinds in the list.
  4. After uninstalling, rename the following folders:
  5. Open IIS (Run > inetmgr) in the Server Manager and delete:
    • Applications Pools > SolarWinds Orion Application Pool
    • Sites > SolarWinds NetPerfMon
  6. Open Registry Editor (Run > regedit) and expand HKEY_LOCAL_MACHINE > Software.
    NOTE: If you are uninstalling from a 64-bit server, expand HKEY_LOCAL_MACHINE > Software > Wow6432Node
  7. Remove the registry keys under 'SolarWinds'.
  8. Reboot the server.
SolarWinds Observability SaaS Network Collector product:
  • Uninstall the SQL Express on the virtual machine. See Uninstall an existing instance of SQL Server in Microsoft documentation.
  • Uninstall the SolarWinds Observability Agent on the virtual machine:
    • On the server hosting the SolarWinds Observability Agent, uninstall the Agent. See Uninstall the Agent.
    • Remove the SolarWinds Observability Agent from SolarWinds Observability SaaS.
Reinstallation and other related articles
To reinstall, see the SolarWinds Platform Products Installation and Upgrade Guide.
If you have problems during the uninstallation, see these related articles:
