Tools
Silent Uninstallation of Dameware Mini Remote Control Agent Service and DMRC/DRS Client using CLI Commands and Automatic Uninstalling
This article describes the process of uninstalling the Dameware Mini Remote Control (DMRC) agent service and client using a silent uninstall, PowerShell uninstall, remote uninstall or automatic uninstall from UI. This also applies to uninstallation DRS and DMRC clients as well.
Uninstalling Dameware Agent Service
Batch command
Run or create the script below in Notepad then deploy it in GPO or SCCM
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. net stop dwmrcs cd C:\Windows\dwrcs dwrcs.exe -remove
PowerShell
- You can create a PowerShell script using the following to remove the service:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. Get-Service -DisplayName "DameWare Mini Remote Control" | Remove-Service
Group Policy Using MSIEXEC
- Below is an example using MSIEXEC to remove the client agent service on all target machines with a group policy.
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. msiexec /x SolarWinds-Dameware-Agent-x64.MSI /qn /l* loguninstall.txt
Uninstall Service Automatically on Disconnect
- Open Dameware Mini Remote Control (DMRC).
- Click on the Settings.
- Click on the "Install Options tab"
- Check the box "Remove Service on Disconnect"
- Click on the "OK" button
Uninstalling Dameware Mini Remote Control/Dameware Remote Support Client
Using CLI command
- Extract MSI from the same version of the installer currently installed to the machine and to an output folder(C:\Temp):
- Note: The filename for the installer will need to be updated to reflect the correct filename (e.g. replace DMRC_Filename.exe with SolarWinds-Dameware-MRC-64bit.exe)
[FILENAME] -out C:\Temp -- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation.
- Silently uninstall using extracted MSI
msiexec /x DWMRC_64.msi /qn -- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation.
Uninstall from Powershell
wmic product where "name='APPLICATION_NAME_TO_UNINSTALL'" call uninstall /nointeractive For example: wmic product where name="DameWare Remote Support" call uninstall /nointeractive wmic product where name="Dameware Mini Remote Control" call uninstall /nointeractive wmic product where name="Dameware Mini Remote Control x64" call uninstall /nointeractive -- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation.
