Database maintenance stops with index errors
This article provides details regarding database maintenance not completing due to a "index entry error".
11/16/2018 5:13 PM
3/4/2025 4:19 PM
Database maintenance shows the following issue in swdebugMaintenance.log and the rest of the procedures do not run:
System.Data.SqlClient.SqlException (0x80131904): Unable to find index entry in index...The indicated index is corrupt or there is a problem with the current update plan. Run DBCC CHECKDB or DBCC CHECKTABLE. If the problem persists, contact product support.
Orion Platform
The particular procedure that resulted in the error may be: apm_dbm_APM_ApplicationStatus_DetailToHourly.  However, this can also happen with other procedures in Database Maintenance.
Please note that this issue is specific to the SQL database and not to the SolarWinds Platform application or any of its modules. We may utilize SQL as many other vendors do, but Microsoft provides support for actual issues with SQL, its deployment, and its environment.
  • If you have an SQL DBA, contact them regarding this error and have them confirm the database is healthy and that the disk(s) the database is stored on is fine. If you have no DBAs, SolarWinds strongly recommends contacting Microsoft for assistance with correcting or repairing the database.
Please, be aware that SolarWinds Technical Support does not include the development of custom scripts, reports, templates, SQL queries, perform analysis of or troubleshoot perfor­mance problems related to third-party products, or SQL or Operating System issues…
