Unable to connect using SSH on Cisco ASA
Connection is refused when testing the credentials using SSHv1.
10/16/2018 1:26 AM
7/26/2022 3:36 PM
This article discusses when you encounter an error "Connection is refused when testing the credentials using SSHv1."
Network Configuration Manager
The device does not support SSHv1.
Change the following to SSH AUTO:
  • Execute command script
  • Config request
  • Transfer config
Change the settings from your connection profile:
  1. Go to NCM > Settings.
  2. Open the Connection profile.
  3. Edit the connection profile
  4. Apply the changes.
  5. Click Submit.
