Security Compliance
Unable to connect to client systems using WMI Providers
This article addresses an error that displays in Patch Manager when you connect to your client systems using WMI Providers. Error message: Details: Although we successfully connected to Some_Client_Computer_FQDN, we were unable to install the EminentWare WMI providers. Detail: Input string was not in a correct format.
When you connect to your client systems using WMI Providers, the procedure fails and Patch Manager displays the following error:
Detail: Input string was not in a correct format.Product section
- Navigate to your Patch Manager directory.
- Navigate to the following directory:
Server\packages\EminentWare - Verify that the directory contains:
wmirdist.msi
wmiproviders_X.X.XXX.exe
whereX.X.XXXis the Patch Manager version. - Remove any additional files in the directory.
- Reconnect to your client systems using WMI Providers to verify that the issue is resolved.
