Tools
Unable to connect to Serv-U using any Protocol using a hostname
This article describes the possible reason why users cannot connect to Serv-U.
7/20/2021 5:36 PM
7/20/2021 5:36 PM
The users may encounter an issue of not connecting to the Serv-U server using the hostname. Random errors show on the FTP client, such as invalid user credentials, unauthorized IP, etc. There is no traffic coming to the Serv-U server when checking the logs.
Hostname resolves to a different IP, not the local or public IP assigned to the Serv-U server.
  • Check the hostname if it's resolving to the correct IP of the Serv-U server using the ping command
  • Use the actual server IP when connecting to Serv-U instead of the hostname
