Unable to add wireless heat map poller to Cisco WLC
This article describes an issue where a wireless heat map poller cannot be added to one of Cisco 5500 Series WLCs having the same firmware. The wireless controller is displayed as X Not a match and cannot be assigned.
11/2/2018 4:44 PM
7/17/2021 2:33 PM
The wireless controller is displayed as X Not a match and cannot be assigned as shown in the following screenshot:
For reference, see Wireless OIDs polled in NPM
Network Performance Monitor
This issue is caused by a missing OID - 1.3.6.1.4.1.14179.2.2.17.1. This OID is required by the wireless controller so that the wireless heat map poller can be assigned.
Contact your vendor and advise that this device OID is required to resolve the issue.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
