Tools
Unable to access Web Help Desk after installing DameWare
This article describes how to access Web Help Desk after you install DameWare on the same server. Both applications use the same port for communications, which creates a port conflict.
11/29/2018 10:59 PM
8/11/2022 2:50 PM
After you integrate DameWare with Web Help Desk, you cannot access Web Help Desk.
Web Help Desk
Environment
  • All Web Help Desk versions
  • Web Help Desk is using Apache Tomcat as an http engine on port 443.
  • DameWare and Web Help Desk are installed on the same machine.
  • DameWare is using http.sys (IIS engine) on port 443.
Workaround
Perform one of the following procedures:
  • Run Web Help Desk using https on another port (such as port 444). The Web Help Desk and DameWare integration runs correctly when both products are using separate ports.
  • Run Web Help Desk and DameWare on the same port with separate IP addresses or network interfaces.
    If you cannot start Web Help Desk due to certificate errors, generate a new certificate. See Using SSL certificates in Web Help Desk for instructions.
  • Install DameWare and Web Help Desk on separate servers.
