Tools
Unable to access Kiwi Syslog NG from remote machine
This article discusses how to access the Kiwi Syslog NG (KSS NG) remotely from another machine and basic troubleshooting steps if you are unable to access the site
- Start Menu > Search > type WIndows Defender Firewall with Advanced Security
- Click Inbound Rules, click New Rule in the Actions window.
- Click Rule Type of Port, click Next.
- On the Protocol and Ports page click TCP.
- Select Specific Local Ports and type a value of 5000.
- On the Action page click Allow the connection.
- On the Profile page click the appropriate options for your environment
- On the Name page enter a name
- Click Finish and restart the computer.
