Tools
Unable to Authorize Email Address, getting a "Need Admin Approval" prompt when setting up Incoming Mail Account in Web Help Desk (WHD)
This article aims to solve the Need Admin Approval prompt encountered when authorizing the oAuth email setup to the Web Help Desk using Modern Authentication for Office 365 e-mail.
Part of setting up oAuth in Web Help Desk (WHD) is to authorize the WHD email address in the WHD oAuth inbox email setup. However, without enough permission, Microsoft Azure will prompt and ask for the admin email account instead of the WHD email address.
If the admin account's email is used, this will sync the admin email mailbox to WHD instead of the WHD email address and process all of its emails to tickets. The configuration should only be authorized by the incoming email account and not any other account.
Important: Ensure that it is the incoming email account configured that is authorizing the connection. Using any other account will process the emails of that account to authorize and delete the emails. This may result in lost emails from that account.
Do the following to assign the correct permissions to the Web Help Desk email address.
Note: Make sure you're running WHD 12.7.8 and above.
- Go to Microsoft 365 admin center and Navigate to All Roles > Roles and administrators.
- Click All Roles > Search for "Application Developer"
- If the Application Developer role is not found in the O365 Admin center, go to the Azure portal and, while logged in using the incoming account, assign the Application Developer role.
- If the Application Developer role is found, add this assignment to the WHD email address. Click Add assignments and enter the WHD email address then click Add.
- Go back to Web Help Desk Console and log in as an Administrator.
- Go to Setup> E-mail > Incoming Mail Accounts and select the existing Email account.
- Click Re-Authorize.
- Sign in using the WHD email address (NOTE: There will be a prompt indicating Permissions requested. Double check that the email indicates there is the WHD email address).
- Click Accept.
- Go back to WHD and make sure that the WHD email address is in the User section of the oAuth settings.
- Click Save.
The Incoming mail account should be processing emails now using OAuth as the Authentication method.
