Unmanage/Manage volumes keeps on generating event in Solarwinds
Volume Unmanaged/Manage is implemented only in 2020.2 as a new feature, the previous version has no such ability
a. Stop all Orion services using Orion service manager
b. Go to Start > Solarwinds Orion > Advanced Features > Database Manager
c. Click Add Server (add the Orion Server)
d. Login using your SQL Orion account
e. Expand your SolarWindsOrion Database and look for EventTypes table
f. Look for EventType 220 and 221
g. Click "Enable table editing"
h. Set MUTE to TRUE and Record to FALSE
-- production or delivery of the scripts be liable for any damages whatsoever
