UDT module is hidden and UDT pages are inaccessible in the SolarWinds Platform Web Console
When trying to access any UDT pages, you see a 403 Forbidden error saying 'you cannot use this feature as your current license does not include access to it.' Even when having the license that should include UDT, UDT pages are not accessible.
When trying to access any UDT pages, you receive the following error message:
403 - Fobidden, Ooops...
To activate an evaluation version of this feature, go to License Manager.
UDT Settings is missing under Product Specific Settings.
The Licensing_LicenseAssignments table in the database does not show UDT:
Performing steps from the article Corrupted license Store in SolarWinds Platform, performing a platform repair, and even performing a clean uninstall and reinstall do not resolve the issue.
UDT module was hidden in history.
To enable module UDT, run a SQL command on the SolarWinds Platform database.
- Connect to the SolarWinds Platform server.
- Open Database Manager from the SolarWinds Platform folder of the start menu.
- Select Add Orion Server, and expand the SQL Server and database in bold.
- Right-click the database and select New query.
- Paste the query into the window and select Execute query:
DELETE FROM [dbo].[Licensing_LicenseFilters]
WHERE [ProductName] = 'UDT' AND [ApplicationMode] = 'Late'
- restart all SolarWinds Services.
If the issue persists after the steps above, try running the Configuration Wizard.
