UDT endpoint information not populating after running through all troubleshooting steps
This article explains what may be causing endpoint information to not be populated after performing several troubleshooting steps.
This article explains what may be causing endpoint information to not be populated after performing several troubleshooting steps. Also, you cannot find anything wrong from the polling side.
See this guide: Endpoints on ports from non-ethernet based VLANs are missing
In some cases, after verifying high fragmentation of each UDT_PortToEndpoint* Tables in the SWDebugMaintenance.log files in C:\ProgramData\Solarwinds\Logs\Orion, the issue can be resolved by defragmenting the endpoints tables with database maintenance using the following article: Critical index fragmentation error displays in the Orion Web Console
