Tools
Troubleshooting guide for Serv-U vulnerabilities
This article is intended as a guide on how to handle a Serv-U vulnerability
Serv-U is a file sharing application and it's main function is to process file uploads and downloads from end-users. A file sharing application can be accessed internally (LAN) or externally through in the internet. Being exposed to the internet creates risks from attackers and a vulnerability scan is routinely done to improve Serv-U's security.
A Serv-U Administrator will reach out to SolarWinds support once they find a vulnerability in the product and we are bound to help investigate and resolve such incidents.
To help resolving a vulnerability issue with Serv-U, SolarWinds Support need to get specific information from you.
- Get the specific version of Serv-U. There are some vulnerabilities that are specific to older versions of Serv-U and can be fixed by upgrading to the latest version.
- the specific vulnerability you are reporting.
- A copy of the vulnerability report.
- A copy of your Serv-U.Archive file. This will enable us to possibly reproduce the vulnerability on our end. This will also allow us to see and investigate their current configuration and look if there is a setting in Serv-U that can fix the vulnerability issue.
Serv-U Support will work any cases solved by:
- Security Configuration that mitigates the issue.
- Article\Hotfix\Update + 100% addresses their concern.
