Tools
Troubleshoot and Resolve Serv-U Gateway Connectivity Issues Caused by IP Address Changes
This article provides step-by-step guidance to troubleshoot Serv-U Gateway connectivity problems, particularly those caused by IP address changes. It helps identify configuration mismatches and ensures proper communication between Serv-U and the Gateway.
10/18/2018 2:11 AM
7/29/2025 10:25 PM
This article provides step-by-step troubleshooting guidance for resolving common issues with the Serv-U Gateway with error messages:
HTTP server listening on port number 43958, IP 127.0.0.1
HTTP SERVER IS NOT LISTENING ON IP ::1: Trying to use non-existent IP address?
HTTP SERVER IS NOT LISTENING ON IP  XX.XX.XXX.X:: Trying to use non-existent IP address?
SFTP (SSH) SERVER IS NOT LISTENING ON IP XX.XX.XXX.X: Trying to use non-existent IP address?
These issues occur because the Serv-U Gateway service is not running properly, is not listening on the correct IP address or port, or when network/firewall configurations block communication.
Verify Gateway Logs
The Serv-U Gateway writes a limited bootstrap log to help diagnose issues
    C:\ProgramData\RhinoSoft\Serv-U Gateway\Serv-U-Gateway.txt
Review this log for any error messages or warnings.
Perform Basic Connectivity Checks
  • Confirm the Serv-U Gateway Windows Service is running.
  • Verify that the Gateway is listening on TCP port 1180 and bound to the expected IP address(es).
  • Ensure that network firewalls and routers allow TCP traffic on port 1180 between Serv-U and Serv-U Gateway.
  • Check local firewall settings on both Serv-U and Gateway machines to permit TCP access on port 1180.
Confirm Gateway IP Address Visibility
If your Serv-U Gateway IP address does not appear in the Listener’s IP Address drop-down when configuring a new Listener:
  • Verify Serv-U is successfully connected to the Serv-U Gateway (look for a green icon in the Gateway list).
  • Ensure the Serv-U Gateway machine has at least one public IP address assigned.
Change the Gateway IP Address entry in the Management Console
  1. Go to the Serv-U Management Console
  2. Go to Global > Server Details > Serv-U Gateway tab
  3. If the Gateway Address is different from the Public IP Address, use the Gateway Address as the Public IP Address as well
Before:
After:
  1. Update all Domain Listeners to use the new Gateway IP address.
Additional Notes
  • After making changes, restart the Serv-U Gateway service if necessary to apply updates.
  • Ensure all network devices between Serv-U and the Gateway allow required traffic.
